Swapping gears
Discussion in 'The Garage' started by 87GMC, Oct 16, 2002.
  1. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    Hears the deal. I've got a Dana 44 sitting in the garage with 4.10, but the housing is rusted. I've got a Dana 44 in the truck with 3.73 in a good housing. I'd like to take the gears and carrier out of the rusted housing and install in the one in the truck. As long as the backlash and the pattern checks out fine, I should be OK, right?
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Basically yes. There are four adjustments that need to be set. 1st is pinion height, 2nd is pinion bearing pre-load, 3rd is carrier bearing pre-load and finally 4th is backlash.
  3. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    if the housing is just surface rust just get a grinder and clean it off then paint it the color of yer choice. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif. later.
    jacob
