swapping in a new tranny.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jonny-K5, Jun 14, 2004.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i just got a rebuilt 700r4 last weekend. im getting ready to swap it in for my worn out trans. what is the best way to go about this? could anyone give me a step by step? i've taken out engines and trannys before, but never on a 4x4.
    do you take off the Xfer case first? i want to know whats the easiest and safest way to do it. thanks.
  2. bga
    bga Registered Member
    Jun 5, 2004
    27
    If you have a Transmission Jack (or access to one) you might not need to drop the T-Case first. It is the safest route however to drop the T-Case to eliminate the excess weight.
  3. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    ok thanks, thats what i thought, any other tips?
  4. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    exactly what bga said.
    I am in SA if you need any help, let me know, I think I am pretty close to you.
  5. socalblazer
    socalblazer 1/2 ton status
    Mar 18, 2004
    110
    Redondo Beach, CA
    I agree that removing the xcase first makes the process easier. I've found in my blazer's that there is a removable access panel in the floor pan to make access to the tranny bolts a lot easier. If you remove the carpet you'll notice that the tunnel will unbolt. I'd check from the bottom first to ensure yours is the same way. I'd remove the torque converter with the tranny too. I'm in Torrance if you need a hand. Good luck!
  6. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    thanks for the tip socalblazer, and thanks to you and funkycold for offering your assistance. i've already bribed my buddy to help me swap them and empty a 12 pack
    hey funkycold, did you ever swap axles? let me know if you've got those 10b axleshafts still. thanks
  7. funkycold
    Apr 22, 2002
    435
    Orange County, CA
    I knew i needed to send you a PM for something.
    Yes I finally brought the 10b home and pulled the shafts for you.
    send me an email and let me know when you want to get together.
    fnkycld@msn.com
