Swapping In New Rear Axel W/ Spring Perches: Pinion Angle?
Discussion in 'The Garage' started by 72k5junky, Jul 18, 2005.
  1. 72k5junky
    72k5junky Newbie
    Jul 9, 2005
    3
    san jose
    Im Swapping Out My 12 Bolt For A Sf 14 Bolt In The Rear, I Measured The Distance Between The Spring Perches And It Looks Like The Perches On The 14 Bolt Need To Come In An Inch Or So, My Question Is: Should I Reweld The New Spring Perches So That It Angles My Pinion Upwards? And If So, How Much Should I Angle It Upwards By? Any Help Would Be Much App.
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Your pinion angle is determined by the type of driveshaft you have and what angle your t-case output shaft is at.
    CV shaft - Set the pinion so it is 1 degree down from pointing directly to the t-case.
    2 regular u-joints - the pinion angle must be within 3 degrees of your t-case output shaft angle.
    Get a cheap angle finder from Lowes, Home Depot, or Harbor Freight etc... http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=34214
