Swapping in TBI and 700R4/208
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by azblazor, Dec 7, 2001.
  1. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Next weekend we are taking out the TH350/NP203 and putting in a 700R4/NP208. The receiving vehicle is a 77 Suburban. The donor is a 87 K5. We are also putting in TBI. Any wisdom, gotcha's, don't forget to......, stuff like that would be welcome. We have the donor vehicle. Any opinions on whether it would be cheaper/better to have the K5 drive shaft lengthened or to have the suburban drive shaft shortened and slip fitting put on??
    Mark
    <font color=blue>azblazor</font color=blue>
    <font color=orange> 79 K5 454-FI / 4L80E, NP205, D60, FF14, 4" lift, 9K Warn </font color=orange>
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    to have a shaft shortened is always cheaper to do.
    make sure you double check all electrical conn.
    take your time, dont rush it.
    and maybe trim your fenders while your motor is out.
    Grant
    PS treat any rust at this time, makes it easier.
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  3. dyeager535
    26,975
    TBI fuel tank out of a Suburban. Sell me your K5 tank. : )
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  4. azblazor
    May 5, 2001
    1,953
    Why wouldn't the K5 tank bolt up into the Suburban? They sure look pretty much the same.
  5. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    i think the FI fuel tanks are baffled, and the pump is already in there........
    i may be wrong howeverr......
    ** i'm so money **
  6. dyeager535
    26,975
    I was going on the typical (?) 40 gallon Suburban tank. (that the K5's didn't get obviously) Was 40 optional or standard? I'd like to know if Suburban tanks are a bolt in, significantly increases my chances of getting a TBI one.
    Dorian
  7. azblazor
    May 5, 2001
    1,953
    I'll put up the post mod lessons learned, to include the fuel tank information. I know that the standard Suburban is 30 something. The optional one is the 40 ish one. But as we are going low buck we will plan on using the K5 tank.
    Hey I do have a question for you Dorian, do you have any tips on using that Camaro tach in your K5?? That's pretty cool.
    Mark
  8. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    You can use a non-baffled tank - I have my original '79 tank with TPI, no problems. That said, if you can, go for baffled for those times you are on an angle and low on fuel, I suppose there could be some fuel starvation problem.
    Also consider the fuel line issue. Are you using an in-tank pump or external? Not sure if the vehicle you are going into has adequate rubber lines for the increased pressure of the TBI pump - tho it isn't a huge amount more pressure over a stock manual/carbed vehicle fuel pump output, is it? For TPI the pressure is 40 psi plus, think TBI is 13ish?
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  9. azblazor
    May 5, 2001
    1,953
    My son wants to go with the inline fuel pump - but I'm thinking we can save ~$100 buy using the K5 tank and pump. He will lose about 30 gallon capacity if you count the axilliary tank we are removing.
  10. dyeager535
    26,975
    Just gotta check Ebay for pictures of one like it. My dad built the thing, and didn't pay attention to what year Camaro it came off of. :( (? www.dorianyeager.com/index2.html
  11. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    I'd take out the inner fenders if i were you, not too hard to get out and gives you a whole lot more access to everything. I'd do it if i pulled my engine again. - Doug
    Doug Krebs
  12. azblazor
    May 5, 2001
    1,953
    Yeah, BTW we just bought "Chevrolet TPI &amp; TBI Engine swapping" written by Mike Knell and published by JTR (Jags That Run). I going to read it, but on first glance it's definately not a cookbook.
    Mark
