Swapping manual to power windows
Discussion in '1992-Present Chevy & GMC models' started by Roostr84, May 15, 2003.
  1. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    How hard of a swap would this be utilizing factory componentry. My buddy has a truck hes parting with all the components. Any unexpected headaches with this swap?
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    It's just a matter of removing the manual window regulators and installing the power regulator in it's place. The doors are usually drilled for all the mounting bolts, it's just a matter of getting everything in place. You'll need the power door panels to, as they have the correct openings for the switches. If your doors have no wiring in them now, you will have to cut the holes in the door and door post to run the wires and fasten the factory conduits which protect the wires, this can be a challenge with the doors on the truck. I would recommend if you are getting these from your friends truck, remove them yourself, so you are familiar with where everything goes and the routing of the wires.
  3. Roostr84
    Aug 19, 2000
    451
    NJ
    Sounds good.. thanks for the info
