swapping my engine... need help
Discussion in 'The Garage' started by 78Suburban, Dec 11, 2005.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I'm trying to keep my ac, and the motor I'm swapping in is non AC. So I'll need to use the double pulley from the fan and PS pump on my Suburban. The fan pulley is no problem to swap out. But what about the power steering pump? The new motor's PS pump doesn't leak like my burb's, but it only has 1 pulley, hence is not compatible with my AC compressor. I think swapping just the pullies would be a major PITA. I wonder how I can find and fix the leak in my burb's PS pump. Or should I just find a way to swap the pullies?
    Also, when I swap in all of the AC and PS bracketry, I'm pretty sure I will have to remove several of the water pump bolts, so will I need to use a new gasket on the water pump? or can I just leave it on and pull the bolts on that side?
    Wow, keeping this AC really is gonna be a pain :crazy:
    Thanks,
    James
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If you've got an auto zone near you, you can rent a pulley puller or you can just buy one, they aren't that expensive. As for the waterpump issue your talking about, I don't think and of the bolts go into the actual water pump MOUNTING of the water pump, but if they do, water pump gaskets are only a couple bucks :thumb:
  3. gmtech954
    gmtech954 Registered Member
    Dec 6, 2005
    96
    ct shoreline
    i would get access to apuller and change the pulley. also for the low cost of water pumps i always put a new one on with any motor swap
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    any tips on pulling and installing a PS pulley?
    thanks,
    James :o :o
  5. mayerichm
    mayerichm Registered Member
    Aug 9, 2005
    15
    Oklahoma
    nope, just use a puller to get them off, then a bolt and washer to get the one you want on
  6. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I"m borrowing one from Autozone tomorrow :D any more tips on using a pulley puller?
    thanks,
    James
  7. mayerichm
    Aug 9, 2005
    15
    Oklahoma
    it should be a power steering pulley puller...that's a mouthful. It's different than a regular pulley puller, it doesn't use three jaws instead it fits over the lip around the center. You'll understand when you get it, and I'm sure the people at autozone will explain it to you...I bet there is a liability issue if they don't.
  8. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
