Swapping spider/side gears
Discussion in 'The Garage' started by SkulzNBonz, Oct 27, 2004.
  1. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Well, I picked up some new spiders and side gears, along w/ a pin, some washers and whatnot (rebuild kit) for my venerable open ten bolt. So what's involved with swapping out the spiders and side gears? Pretty straight forward, or are there some tricks, quirks, or any little hang ups I should know before I tackle this job? Probably gonna swap the gears in after work today. TIA.
    John
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    it's not a bad job. Just have to play around with the install sequence of the spiders some til you get them to all go in the way they should. /forums/images/graemlins/thumb.gif
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Besides having to smell gear oil, its an easy job /forums/images/graemlins/thumb.gif
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Pull the cover, pull the pin (8 mil bolt head, 6 point), push in the axles, C clips fall out, take out spiders, side gears and all shims.
    Put the new side gears in, with oil between the shims and side gear, put the spider gears in, THEN put the shims for them in, C clips, new pin and bolt, cover and oil.
  5. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Thanks all /forums/images/graemlins/waytogo.gif Got rained out yesterday, so I'll be tackling this today /forums/images/graemlins/peace.gif
    John
