swapping steering boxes, need quick help.
Discussion in 'The Garage' started by muddybuddy, Dec 10, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey there, im swapping my 4wd steering box out for a 2wd box to do crossover, and i need help disconnecting the steering shaft from the box. i have the 2 lines out and i know there are the 4 bolts that are in the saide of the frame. at what point do i disconnect the steering shaft, so i can take the box out? sorry if it doesnt make 100% sense, hopefully u understand what im trying to do :doah: :D
    thanks,
    james
  2. az ranger
    az ranger 1/2 ton status
    May 9, 2004
    139
    Safford AZ
    I Just Changed Mine Out Last Week And I Took The Two Bolts Out Of The Rag Joint Where The Shaft Meets The Box Then Took Out The 4 Bolts That Hold The Box To The Frame. Once The Box Is Free You Can Pull It Away From The Shaft. The Steering Shaft Should Also Collapse A Few Inches If Necessary That Helps When Reinstalling
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    alright thanks, ill go back outside in the 25* weather and continue :-)
  4. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    Why not just swap sector shafts? It is soooo much easier! Four bolts and voila!
    -- A
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    haha well well i already got a 2wd box tapped for hydro assist so....haha. i got it out, jus gatta call a buddy up to help me line the holes up, i dont wana spend all day trying to line them up myself
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    should my 4wd box rag joint work with the 2wd box? its not fitting?
  7. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    mine was the same
  8. dremu
    Feb 27, 2000
    15,970
    462
    Fair nuff -- and sweet!
    -- A
  9. big adam
    big adam Newbie
    Dec 17, 2005
    modesto ca
    stearing box
    i would like to know if the 2 whl stearing box works wiyh no modifications. plus i'm looking for a full cage fore my 1975 jimmy that im installing 1 ton running gear in soon. looking for some better stearing . thanks adam abasikowski@sbc global.net
