swapping steering wheels?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Boss, Nov 15, 2000.
  1. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Just wondering if a steering wheel puller is absolutely neccessary to remove the steering wheel? I'm swaping out my wheel for a Grant wheel. I read in my Haynes that you need a steering wheel puller to remove the wheel...is that true? I figure I would just yank it out or bang it out or something. Don't want to spend $ on a puller if I'm only using it once, unless I absolutely need it. Thanks in Advance.
    Boss
    http://www.boss.coloradok5.com
  2. IH82LUZ2FORDS
    IH82LUZ2FORDS Registered Member
    Sep 25, 2000
    23
    Fargo, ND
    I suppose technically a steering wheel pull in not necessary but I really recomend it, they are cheap and you never know when you are going to need it again. But if you don't want to buy one, heres what I would do.
    First Pull your seat as far as it can go, while you sitting in it. Then place you knees up behind the steering wheel, then put your forearms behind the top of the steering wheel, have a friend grab a hammer and then have him hit the steering wheel from behind, while you are pulling as hard as possible on the wheel, will take a lot of work, the c*ck sucker is on there good. But getting the wheel off is the easy part, I don't know if you have to, but you might have to take off the pressure plate to install a new wheel, thats kinda hard too, but they also make a tool for that. Good luck, let me know if you have any q's.
    Rob, 88k5
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You could just rent a puller, most rental shops have them...
    [​IMG]FUN WITH 31's![​IMG]
  4. jim82
    jim82 Registered Member
    Jun 27, 2000
    71
    Bay Area
    just check out an autozone or checker, they make you deposit what its worth but when you give it back they refund you everything. it works out really good for those tools that you only need to use once.
  5. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Just get a puller. 8 bucks or so. DONT BANG IT OFF WITH A HAMMER. YOU WILL SCREW YOUR STEERING COLUMN.
    When all else fails... Check the blinker fluid.
    78 K-5
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    My steering wheel puller cost $4 from Autozone. Little thing, nothing to it, but neccessary.
    Think about how you'll feel if you cheese out on $4, then mess up your $$$ steering wheel.
    Good luck.
    -- Mike
  7. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    When I got my Blazer I one of the first things done to it was replacing the stock wheel with a Grant. I did not use a puller I did what any 16 year old would do and bang the hell out of it with a hammer, and it worked No damage what so ever! I consider myself lucky. Do yourself a favor and by the puller!
  8. You could always use a harmonic balancer puller if you have one laying around and if it fits, of course
  9. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I can't imagine how insanely hard it would have been to swap mine out without a puller. I paid $7 for mine at a Western Auto I think. It'll save you alot of time and you won't run the risk of jacking up your steering column.
    '73 K5
    Chevy good...Ford bad
  10. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    BUY THE PULLER !! lol.
    I just put a newer model 4 spoke in my 83 and it was a beyotch to remove the wheel's. I beat the wheel with a hammer, sat in the seat.. tried pulling with all my might, no go.. I removed it by using a ball peen hammer hitting the center of the wheel where it's held on my the nut.. it came off.. And I'm glad I did no damage to the column.
    Steering wheel pullers are only like 5 bucks in JC Whitney.
    It's better to have it than to need it, than to need it and not have it !!!!
  11. Boss
    2,550
    Maryland
    Cool, thanks for the info. I never priced a puller so I didn't think it was that cheap. (thought it was going to be like $30+). Anyways, guess I'm going to the parts store after work today to get a puller. Thanks for all the info and help.
    Boss
  12. slash
    slash Registered Member
    Nov 14, 2000
    5
    Great website - thanks for all the tech tips! BTW AutoZone and most other parts store lend the tool for the steering wheel job. Works like a champ and takes way less time for the job...good luck!
  13. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    good choice, but now, just because you decided to buy one you will never use it again....lol
    Knife.
    knife.coloradok5.com
  14. CruisinK5
    CruisinK5 1/2 ton status
    Jul 8, 2000
    164
    Georgia
    I have put several different steering wheels on my K5. I bought a puller the first time when I was replacing the stock wheel with a Grant. The second time, I went to take the old Grant wheel off to realize that Grant makes a puller and it is different from the stock one. So I ended up having to rig the other because it was late and the stores were closed. Just something to watch out for the next time you go to take it off.
    "Have you driven over a ford lately?"
