swapping TBI 350 for TBI 454
Discussion in 'The Garage' started by beater_k20, Dec 7, 2006.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    can this be done without a 454 wiring harness? ie, can i reuse my 350 harness. i know some custom tuning will be in order, but that was expected anyways.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh it can be done, on mine I think the TPS was the same, but the IAC was different.
  4. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    I swapped in a 454 harness when I did the 350TBI to 454TBI swap. I believe the 350 harness would have worked by swapping out a couple of the connectors as stated by others, but with the larger engine size it would have been a stretch to try and make the harness fit right. If you have access to a 454 harness it will fit and look better.
    Russ
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    just thinking, because i have a 350 harness already in the 92, and i've got my eye on a 454 with TBI. no harness, and 454 TBI trucks are hard to find in yards around here. :thinking:
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    buy it, figure it out later.
    i used a 4.3 harness on a 350 swap in a s10. we had to lengthen a few wires (o2 and knock sensor), but all the plugs are the same from the 4.3 to the 350. you can buy just the pig tail for anything that is different and rewire it to use your 350 harness.
