swapping the mouse for the rat
Discussion in 'The Garage' started by bgwhlr, Feb 18, 2003.
  1. bgwhlr
    bgwhlr Registered Member
    Feb 18, 2003
    14
    Tigard, OR
    Hello, I am new to the site and need some serious input...
    I recently finished a 454 for my 72 K5 blazer. It won't fit the 350cu inch location due to the cross member hitting the 454 oil pan, what are my options. I also recently found the big block towers for those years, but they don't bolt to the cross-member. Please help, need to get motor in for 4x4 event on March 1st /forums/images/graemlins/confused.gif
  2. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    Got cutting torch? /forums/images/graemlins/laugh.gif
    Sounds like you need to modify something. Hopefully someone who has done it will speak up.
  3. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    thats weird cause I got a 454 in my 71 and all we had to do was caress the firewall (bash it in other words) to clear the valve cover, and modify the clutch linkage, beings mine is a 4-s[eed. and other than that it fit easy. maybe a different oil pan?
  4. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I'm days away from sitting a 454 in my 69 K20 and I've been collecting info as I prepared for this swap. Generally I have gathered that the major problem will be the firewall clearance. I'm doing a 2" body lift for other reasons that should fix that problem. Haven't heard of the oil pan being a normal problem. I have learned that the 72 big block tower's don't work without modifying them. Some people have recommended getting a crossmember and towers from a 73-up - but I haven't followed up on that. I'm just gonna cross my fingers and see what happens with mine.
  5. bgwhlr
    Feb 18, 2003
    14
    Tigard, OR
    Thanks for the info, I did take the cutting torch advice, and now I've added 1.5 inch drop by welding in spacers. It now clears, and also the sledge hammer intro to the fire wall worked well for the drivers side rocker covers. thanks again.
