swapping to manual
Discussion in 'The Garage' started by krechj, Nov 8, 2006.
  1. krechj
    krechj Registered Member
    Nov 14, 2005
    33
    Murderapolis, mn
    so i've found 2 early 90's chevy 1500's with 5 spd trannys and im considering swapping out my turbo 400 for a manual however i dont really know alot about chevy's manual transmissions except for the sm456. my guess is that these trucks have the nv4500? or do they have something else that i dont know about? these seem to be way to cheap though beacause from what i've heard the nv4500's are pretty pricey. any help would be great thanks guys!
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    post up a vin# and I should be able to tell you what trans it is.
  3. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    If they are 1/2 tons they arent' 4500s. They are Getrag 5-speeds, good for a driver, but dunno bout a wheeler.....
  4. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    thats not always true
    some 1/2 tons had the nv4500, especially if it a w/t 4x4 and if so you've found a 14bsf with a 6 lug also.
  5. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    i'm assuming that the 90 models are 4x4? other wise how are you going to get it in? or are you looking to swap a tranny in a 2wd?
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Unless they made 1500hd's then they didnt. that would be a light duty 2500
  7. krechj
    Nov 14, 2005
    33
    Murderapolis, mn
    thanks for the help! but from the sounds of it they arn't gonna be the nv4500's however i suppose i'll check anyhow just to make sure i dont pass it up. anyone know about the getrag 5spd? im looking for a tranny with a lower first gear than the 400... otherwise i'll just stick to the sm465
  8. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    they did make a 1500 hd i saw a new new model(oh i would say it was an 03 or 04) the other day i was admiring the 8 lug rear disk brakes thinkin i need that rearend...i looked at the rest of the truck checkin it out and on the door 1500hd..i said holy ****, look thats a 1/2 ton with 8 lugs, talking to my wife she said u know i don't care about that ****!
  9. goldwing2000
    goldwing2000 Guest
    What're you gonna do with your 400? :whistle:
    :D
  10. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    I used to own a 94 chevy 1/2 ton with a NV4500. It was the only non 1/2 ton part on the truck. It was an option that only a few people went with. Loved that granny gear.
  11. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    The 4500 was an option on the 1500's starting in 92- possibly late 91. The 6-lug SF14 was an option too, from 88 til 95 or so. You can ID it by looking at it, it has a large black iron case with an separate aluminum bellhousing. The LD 5-speeds are one piece with integral bellhousing and are bright aluminum. They were offered starting in 88 or so. I've beat on one pretty hard- hard enough that I destroyed the open 10-bolt behind it and though it showed signs of wear it never gave up. You should be able to bolt one up to a NP208 or 241 out of an earlier truck to do the swap. The main problem area is the internal slave cyl on some of the later year models. I had to replace the slave on my 93, but it was external- I just had to loosen the starter to get it completely out.
  12. krechj
    Nov 14, 2005
    33
    Murderapolis, mn
    haha t'll prolly sit around the garage for a few years till i someday find something to do with it or end up putting it back in... however if someone were to make an offer everythigs for sale for a price lol it does only have 40,000 on it! im still debating about even doing the swap though so we'll see what happens
  13. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    well def swap to a manual.... and go hydraulic clutch ta boot.. either way you wont be happy.. I had a turbo 400 with a b&m shiftkit.. shifted like hell.... rip yer head off it would..... but went to a manual... cant shift as fast but the power is where I need it..never have the CRAP IM BOGGING!!!! drop that gear and hammer down :haha:
  14. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    nudder vote for the stick!
  15. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I'm swapping my built 400 for a 465 too. 465's are a dime a dozen, I wouldn't trust a LD 5-speed and a 4500 is $$$.
  16. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    .10 a dozen
    well i'll take about 5 dozen, i just barely have 2 quarters to rub together, but i guess i would part wit em for 60 sm465's, i've been lookin for just 1 for about 2 years now that has a 203 adapter so i can do my crawler with a doubler!! they just not in this part of the country!...
    i've been told that the 400 with the 203 adapter is the way to go anyway, when you realize your in to low of a gear and your sinking and you have to clutch it to grab a gear might be just long enuff to stick you there once you lose that momentum, with an auto if you realize your going to slow you just gas it!!
  17. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    if i was to build a pure mud truck i would probably go with an auto. otherwise i dig the stick IMO
