Swapping to Serpentine belt
Discussion in 'The Garage' started by 73K5Kid, Jun 4, 2003.
  1. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
    I did a search and came up with a few answers. But still have a few questions. Will it matter if my set up came with ac. And if I am not running ac what will I have to change. I already changed fan clutch and bought a reverse water pump. How hard is it to change out the power steering pump. Thanks in advance
  2. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    Need more info. You are putting the setup on a 73?
    If so you should just get the entire setup off a donor vehicle, ps pump and a/c compressor included. May have to switch the compressor from one side to the other if yours is setup the same as the 80's Blazers
