Swapping Trannies: need help
Discussion in 'The Garage' started by jimmyjack, Jan 22, 2003.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    Tucson Az
    My 700R4 is trying to turn itself inside out. It still runs but it's definately circling the drain. I found a 350 I can throw in it's place. Question is, will the cooling lines and dip stick from the 700 work on the 350? I have a 208 tcase from a 350 so it'll swap in OK
  2. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    i just did this a few months ago
    you will need to an adapter for the 208 to mate to the 350
    you will need to have your rear drive shaft leghtened
    and the front shortened,
    a cross member for the 350, the 700r one will not work
    maybe exhaust redone cause the crossmeber will be moved forward and hit the y pipe,
    you would prolly be better off to find a 205 tcase for that th350
    someone with more nohow will come long and give ya more info,
    sorry i couldnt be of more help but im learning as i go
