swapping yokes...
Discussion in 'The Garage' started by beater_k20, Oct 9, 2006.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    having broken a bolt in the yoke on the 8.5" 10 bolt in my C1500, i have another that i'd like to replace it with. if i remove the yoke, is it possible to reinstall the new one without having to pull the rear apart and replace the crush sleeve?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Sure is. I'd mark the nut and the pinion, remove and replace the yoke, install the nut so the dots line up and then maybe an extra 1/6 of a turn.
    The wear in the bearings will probably require a little more crush on the sleeve anyway.
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    just make sure you check the preload before taking it apart and make sure you get the same readihng afterwards, you also might want to check the pattern just to be safe
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    honestly, if the gears blow up a couple months down the road, i dont care. by spring this thing wont even be on this chassis anymore.
  5. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Like was already said just remove the yoke and replace it, but dont forget to replace the seal.
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    its leaking anyways, might as well...
  7. Corey 78K5
    13,055
    Humboldt County, CA
    You always replace the seal because You are pretty much guaranteed to ruin it as you pull the yoke out. It's like replacing the throw out bearing when You do a clutch, they go hand in hand.
