sway bar and relocating axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sparky, Feb 3, 2003.
  1. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Anyone get away with moving the front axle forward 1 in. or so and still able to run the front sway bar? (I have the ORD disconnects and 4in. tough country srpings.) What about the stock front driveshaft?
    Sparky
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Since you have the disconnects you will probably still be able to run the swaybar you will just have to angle them rearward as for the driveshaft wakeboard&4x4er is still running his stock front shaft with the about the same setup (4" bds springs) with a 1" zero rate to move it forward and no problems yet but we are looking at adding a 1" spacer just for piece of mind, but since you did not mention a zero rate just moving it forward you should be fine..
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    I just took my swaybar off, i haven't noticed a difference on road, but flex is TON better.
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Can you run stock steering and move the axle 1" forward, or what is needed to correct it?
    Dan /forums/images/graemlins/burb.gif
  5. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    You will have to shorten the draglink by unhooking one side and loosening the bolts on the connecting sleeve and turning it accordingly. Really simple.
  6. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Thanks, I know how to shorten it, but was wondering if there is enough to do so.
  7. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Should be, just do 1/2" on each side. Didn't mean to imply that you didn't.
