Sway bar bolt size?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jcg, Jul 23, 2000.
  1. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I'm making swaybar disconnects and I need to know what size the bolt is. I would measure my own truck but it's still at the body shop and I want to get these done by Monday afternoon so I can possibly install them before they put the fenders back on. I need the diameter of the bolt and the length of the bushings in the end of the bar.
    On a side note (nothing to do with K5's), can anyone recommend a good marine radio (CB)? I just bought a 20' Century and it needs one before I go on vacation next week.
    Thanks guys...
    Joe
    Rochester Institute of Technology Team Mini-Baja
    88 Jimmy
  2. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Bolt is a 3/4" bolt with a 1 1/8" head. The measurement of the bushing is roughly 1 3/4" - 2". I made my own swaybar disconnects too.
    Mudzer 1978/91 K5
  3. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    Thanks Mudzer, I knew someone on here would have that info laying around. Looks like I'll be spending tomorrow afternoon in the machine shop.
    Joe
    88 Jimmy
  4. Nike
    Nike Registered Member
    93
    Jefferson City, Missouri
    I am doing the same project. I bought a polyurathane swaybar bushing kit from one of the aftermarket suppliers for about 30 bucks and you get a set of bushings for the swaybar which can be used on your bracket if the ones in your actual swaybar aren't in too bad of shape. You also get a set of poly front supports (greasable) and the brackets. There is a certain size schedule 40 pipe, or it may be .120 tubing that will work with these bushings but I forgot the size, go to your supplier with your handy metal inside / outside measuring device. You will then need to pick up a 3/4 " pin from a farm supplier to attach the swaybar to your bracket and you should be in business. Hope this helps. Nike in Mo.
    Blue
