sway bar bushings
Discussion in 'The Garage' started by TxK5Blazer, Sep 13, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I just replaced my sway bar bushings today and noticed that when I tightened the straps down on the front if I tightened them all the way to where the strap touches the mounting plate then the bushing was deformed is the correct or do I back them off where there bushing looks normal......Jason
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    The brackets need to be tightened all the way down. Do you have the correct size bushings? There are 2 different sizes.
  3. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    I have the 1 1/4" sway bar with those bushings so I will tighten them all the way down just seams the bushings distort when you do that but not a problem....Jason
