SWAY BAR DISCANECTS?
Discussion in 'The Garage' started by Chase, Mar 10, 2004.
  1. Chase
    Chase Registered Member
    Oct 23, 2001
    18
    ARE THEY CHEAP EXPENSIVE HOW THEY WORK I GOT A 90 GMC SUBURBAN WITH 4"LIFT AND 35"TIRES HELP ME OUT PLEASE
    /forums/images/graemlins/burb.gif
  2. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    What's a sway bar? /forums/images/graemlins/confused.gif
    Just kidding I threw mine away I think ORD sells them for like one bill or about! /forums/images/graemlins/thumb.gif
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Basically you pull a pin and your swaybar is no longer connected giving you more flex, when done wheelin, line it back up, put pin back in and you have road handling. I think they also raise your swaybar mount. Sotck your swaybar was like --- that angle, now w/ a susp lift yours prob looks like mine at \ angle. WIth the kit it gets it back closer to --- so it will ride smoother. I agree, about $100 or so.
  4. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    Is this a DD? I ditched the swaybars on my '90 K5 and used to drive it 55 miles everyday with no problems. You just got to take the interstate off-ramps a bit slower and maybe get some motion sickness tablets for your passengers. /forums/images/graemlins/rotfl.gif With the 'burbans extra wheel-base, I'd guess you won't miss your swaybar much at all.
    I read your other post about "flex". Shackle flip will help that out a bunch. I used an ORD, but there are some "home-brew" creations that will give you the same result. I've actually got a set of stock shackle hangers laying around. You could cut them up to make a shackle flip like tRusty did on his K5. (Ok, I couldn't find tRusty's but here's a link to one found in the technical section, http://coloradok5.com/shackleflip.shtml )
    PM me if you need an extra set of hands to work on your rig.
    Lance
