Sway bar disconnect swap
Discussion in 'The Garage' started by GM4wheeling, May 23, 2006.
  1. GM4wheeling
    GM4wheeling 1/2 ton status
    Apr 10, 2006
    337
    Ft. Bragg NC
    My 74 K10 has a 3" lift and has the swaybar disconnects on it. I don't use the truck for wheeling anymore, just haul junk in. But would the disconnects fit on my 87 K5 with a 6" lift? I think I'd definetly get more use out of them if I had them on the blazer? It looks like the swaybar is all the same on both trucks but wondered if anyone knew for sure.:thinking:
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    itll work fine...On the blazer with 6" of lift just loose the sway bar, you wont notice the differance.
  3. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Must be sway bar question day. I asked a swaybar question also, I am taking my disconnects and sway bar off, I think it is more of a hinderance then anything.
  4. GM4wheeling
    Apr 10, 2006
    337
    Ft. Bragg NC
    guess I'll just unbolt the sway bar from the axle on the blazer and see if i notice it not beeing there... then deciede if i need to take the disconnects off the K10
