sway bar disconnect
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4wood, Dec 3, 2003.
  1. 4wood
    4wood 1/2 ton status
    Jul 27, 2003
    116
    Atlanta, GA
    I see ORD sells a swaybar disconnect kit that will go along with 2" of lift. So...suppose I'm looking to go with a 4" lift, is there an easy way to modify this one or is there another company somewhere that sells a kit for a 4" lift? 'preciate you.
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I believe the disconnects also work fine on 4" lift.
    I have them on my 4" lift.
    You might want to post a message in the ORD forum /forums/images/graemlins/thumb.gif
  3. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    The swaybar kits from ord will work fine with a 4" lift. They only raise the swaybar up 2 inches though, because if they went any farther, one side of the swaybar brackets would hit the frame. I have ord's kit with a 6" lift, and there are no problems. /forums/images/graemlins/thumb.gif
    -Harrison
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    btw, ya might wanna take ur anti-away bar off and drive around for a week or so to see if you even need/want one or not. I took mine off a year or 2 ago and havent missed it since. Had the disconnect kit fot a while, then sold it.
    j
  5. chebywanna
    chebywanna 1/2 ton status
    Apr 20, 2003
    277
    streamwood, (chicago)
    someone once said that you can't have a sway bar with cross over, you guys know if thats true? (as in fizically impossible or something like that).
  6. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    My disconnect works just fine with my 6" lift. I like to keep my swaybar connected for the road because it makes the truck handle a lot better. I have soft springs though so if you had stiffer springs you may not need a swaybar at all.
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The new Draglink goes right where the sway bar lives. I never missed my sway bar.
