sway bar disconnects??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90blzr, Apr 23, 2001.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    On the sway bar disconnects, are they worth it if you dont "plan" on disconnecting the sway bar. Sound like an obvious answer, but I was reading that they relocate the sway bar for a lift and makes it handle better and everything. It sounds like this might be better to do this than get the sway bar relocation kit with the lift kit. Any info would be appreciated. Maybe I'm just really lost!!!
  2. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    i have the warrior disco's on my 1990k5 and they work gr8--and if you wheel at all they are an absolute must!!! +their cheap
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would do it you will be happy with it
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  4. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    What are the warrior disco's?? Where do you get them and how cheap? Are they like ORD's????
  5. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
  6. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    I have a set of used ORD swaybar disconnects that I am taking off a truck and will be selling if you are interested.
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
  8. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Swaybar? Whats that? I've had mine off my rig for 2+years now and love it. Noticed very little to no difference in sway. But a huge difference in wheeling.
  9. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    I sent you a private. Why dont you want them if they are so good??
    And does any one have an answer to my original ?? Are there any advavtages other than disconnecting the sway bar. I dont think I will be cause I'm not crazy about the sawzall. Looks good on everone elses, I just cant seem to start cutting up my fenders. Or should I just get the sway bar relocating kit?????
  10. Storm Trooper
    Nov 24, 2000
    4,640
    ORD disconnects work great but I agree with waxer, I can hardly tell a difference with them off. They do raise the rear location to the axle which will help it work better with a lift. New bushings help also. Is your truck just for street?
  11. K5BLT4FUN
    Feb 28, 2000
    496
    Peculiar, MO USA
    The reason I have a set that I am taking off is that I am doing a crossover steering conversion and the sway bar will be in the way. I have a 6" lift up front and instead of relocating the swaybar I used the ORD disconects and it helped the ride and the bumpsteer somewhat. The disconnects main function is to allow more articulation offroad, which they do. If you are a weekend warrior and use your K5 as a daily driver I would recommend the disconnects, but if you just use the K5 to wheel in then remove the sway bar and enjoy the articulation.
  12. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    It is primarily on the street. Will be about 80/20 or so. Dont want to cut the fenders thogh. So from what youguys are saying I should go with the disconnects rathere than relocating kit right? Thanks for the help!!
