sway bar drop??
Discussion in 'The Garage' started by NEK5, Jul 5, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    anyone ever heard of it?? my buddys got a 90 like me with the 4 inch, but stock tires, and he gets bump steer, from what he described to me, and he talked to one of his dads friends that had a blazer too, and he said he dropped the sway bar and it stopped???
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I'm running 4-6 inch lift sway bar drop brackets from skyjacker. Frees up some movement as well
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    What's a sway bar????
    Anyhow, it might help a little dropping it down. You can also get a set of ORD discos and raise it up about 2" on the axle end.
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    ord dissconnects are the way to go cause they allow the sway bar to move in an arc an not bind up...
    if it were me, id ditch the sway bar
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I agree I have not had a swaybar in almost 2 years:D . My truck is actually stiffer with the 4" lift springs than with the wornout stockers:D .
    Ira
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I fitted the ORD QD kit and it smoothed out my suspension really well.
    Then I junked the sway bar and never regretted it.
    Then when I went to cross-over and found that for street use I was really 'pushing/pulling' the axle about under the truck at low speed manouvers so I built a QD panhard rod and it's sweet now!
  7. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    hmmm, i wonder if mine is...:thinking: ....if it isn`t i dont think i want to ditch the sway bar, unless you give me a good reason too, should i just get an ORD QD?
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Mine had nothing to do with bump steer, it was just causing a very stiff ride as the axle tries to move in a different arc to the sway bar which is now (after the lift) at a steeper angle than before. The ORD set up REALLY made a difference to the ride quality. Plus they're easy to disco when you want more flex! (as long as you're on flat ground!)
    You can't use a sway bar with cross-over anyway, hence the panhard rod.
  9. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    what should i look for on mine?
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Why? What problem are you having?
  11. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    well it does seem that the front is very stiff, and i get a little bumpsteer, i`m just wondering if the PO ever dropped the sway bar...
  12. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Probably not. Most of the kits that I looked at neglected to include anything for the swaybar.
  13. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    so what should i look for to see if mine was dropped so that way if it isnt, i can
  14. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    If it's bolted up to the chassis cross member direct and onto the spring plates direct it's stock. Unbolt it and go for a short drive. You'll notice a massive difference. Just don't try to race anyone or slalom any traffic cones until you're used to driving with out. normal driving you won't even notice the difference in sway.
  15. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    For what it's worth, when I installed my 6" kit, the swaybar wouldn't even come close to going back on. I set it aside and decided if I needed I would get the ORD kit. I haven't spent the money yet and see no need to. Take the swaybar off and see if you really need to be concerned about it.
  16. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    That's what I did. And I'll tell ya, when a Suburban starts swaying at 55+ mph, the pucker factor is high! The ORD disco is awesome.
  17. wicked87_k5
    wicked87_k5 1/2 ton status
    Aug 9, 2004
    235
    Little Falls,NJ... North
    I removed the sway bars on both my :k5: :k5: , 4" + 8" lifts. Both ride better without it. The only thing that sway bar is good for is:whistle: scrap.
  18. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    I go through more than a few traffic "roundabouts" just about every day. For those that don't have these fender-bender loops, you do a fairly hard right to enter the roundabout, followed by a left bank around it, then another fairly hard right to peel off the roundabout. The quick succession of right-left-right is just great for inducing body roll.
    When I first bought the truck, it really body-rolled on the roundabouts like a boat in a tight turn (though leaning out rather than in, of course). New shocks helped a tiny bit, but poly bushings on the front sway bar killed a lot of roll, and the ORD steering brace also killed some swaying.
    I can go through these things now at the posted speed, feeling stable, and without appreciable body roll. Being beefy enough to discourage most vehicles from pulling right in front of you helps a lot in this circular ballet, and little cars get cut off all the time by smaller SUVs and minivans. A K5 isn't an F-650, but it looks like too much potential collision damage to your new minivan to risk a bump.
    If it was mostly a wheeler truck, instead of a 99% DD for me, I'd consider ditching the bar, but those roundbouts would be mighty wallowy without a sway bar.
  19. cbbr
    Jul 17, 2004
    14,681
    You have any good pictures of that setup?
  20. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    my truck sways in and out of the lanes a little on the highway, could the sway bar be the culprit? or my 20psi tires?
