sway bar help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Mar 11, 2001.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    can someone show me a pic of a sway bar, and where to disconnect it please. i want to disconnect mine, but im so confused on what todo and where its at.
    thanks
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    to disconnect the stock sway bar up front you need to remove the bolt's holding it onto the rear and the grommet's holding it to the frame under the rad support,,,if you mean to disc. it just for wheeling and then put it back on afterward's,,,you need to buy a disc. kit...one from <font color=green>ORD</font color=green> would work well [​IMG]
    your welcome steven watson[​IMG]
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The sway bar bolts to the U-bolt plates. All I did was unbolt it and bungee cord it up for wheelin'. Then I got lazy once and realized with the front springs I have the sway bar just wasn't necessary. I chucked it into the back yard and its been there 3 years now [​IMG]
    Eventually when I get softer front springs I'll get a disconnect kit and put it back on.
    Rene
  4. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    is it the long bar infront of my front axle?
  5. k5king
    Jul 23, 2000
    571
    of you look at the axle,,where the spring's bolt up to it,,there should be a thick plate that hold's the spring onto the spring pad,,,the is a huge bolt going into the side of it,,attached to it is the sway bar,,,just unbolt it there,,the one in front of the axle is the tie rod,,,do not unbolt it,,[​IMG] if there is nothing there then you don't have a sway bar on yur truck,,some did not come with them..
    [​IMG][​IMG]
  6. sluggo45acp
    sluggo45acp 1/2 ton status
    Jan 2, 2001
    472
    Northern fortress, Republic of Texas
    Yep thats it.[​IMG]
    [​IMG]IF EVERYTHING WORKS IT AINT A REAL TRUCK[​IMG]
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The long bar in front of the axle is the tie-rod, you definitely don't want to disconnect that........
    The sway bar comes off of the U-bolt plate and heads forward and up. When it gets to the front cross member it is secured to the cross member with two bushings. Crawl underneath and have a good look at it.
    Rene (no scanner, no pics....[​IMG])
  8. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    ok i found it!!! EURIKA!!! [sp?]
    thanks to Dawson444 taking som epics for me!!! thank you!!
    now i dont feel like as much of a dummy!
    thanks!!
    i love the message board!!!
