sway bar, off or on?
Discussion in 'The Garage' started by wraenking, Jan 18, 2005.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    ok, im putting the 4" lift on , and i need to know if i can just leave the sway bar on, or do i have to put spacers on it or what?
    i can always take it off later.
    thanks
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you keep it you need stock steering and a disconnects . OR you need to space the frame brackets so it still lines up :k5: :k5:
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Take it off and dont look back, best thing I ever took off my rig :)
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    toss it:waytogo:
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I don't have mine. They made it into a Nissan. Take it off and drive the truck. If you don't feel you need it then turn yours into a Nissan too. If you think you do need it then put it back on and get some ORD discos.
  6. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
  7. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
  8. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Wire it up disconnected and drive it. If it doesnt bother you remove it and throw it away!
  9. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    exactly what ryoken (paul) told me.
    in the last ten minutes, i removed it:)
    so onlt=y a test will tell. if that many people dont run it, i think it should be ok
  10. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    My 70 didnt come with one from the factory and its got 320,000 miles on it. Unless you are really concerned about high speed body roll you'll be glad its off when you are off road!
  11. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    just don't take sharp turns like speed racer and you'll be ok.. I "attempted" to do donughts at work when it snowed and my buddy said my truck looked like it was going to tip over.. it's fun to see the reaction on passengers when your driving and you turn and they feel the truck start to sway to one side.. you just get used to how much sway your truck can take.
  12. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I put the 4" Rancho Pre-runner springs on my Sub and I kept the swaybar. I prefer driving with it on, but I do not rock crawl the Sub either. It's a desert race chase/Expedition machine.
  13. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    I've got a 3/4 ton sway bar on my truck and I love it, next to no body roll when driving. My buddy has a 3/4 ton 4x4 without one, and it is almost scary how much it leans. I mean, the thing sticks to the road just as good as mine, just leans like crazy, which makes it much harder to control.
    Basically, if you plan on offroading the truck, take it off as it seriously hampers the amount of flex your truck has, which makes it so you could loose traction when you might have had it without. But if you plan on just driving it down the street, keep it for the better on-road handling :)
  14. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ditch it. I ran no swaybar on soft 2.5" springs and it wasn't bad. I now run 4" springs without it and I would never want it back. It is just a headache and extra weight that is not needed.
    Harley
  15. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    With Pro-comp springs you'll never notice the difference...toss it.
    Rene
  16. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    take it off, drive around for a week (being aware that things may feel different... be safe) and then go from there. Personally, I removed mine and never looked back. Others opinions do vary.
    j
  17. timmay
    timmay Registered Member
    Oct 24, 2004
    62
    Here
    Another vote for no sway bar.
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Dead weight, dump it.
  19. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    unhook it , try it .
    if you no like , hook it back up.
    i left mine hooked up after my lift. i think it helps from keeping the
    wheels from rubbing when taking sharp turns. plus i like the tightness.:D
  20. divorced
    Jul 20, 2004
    5,115
    :hack: :grind: :weld: :hack: :grind: :weld:
