Sway-bar or No Sway-bar
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by magnum4x4, May 17, 2004.
  1. magnum4x4
    magnum4x4 Registered Member
    Jan 4, 2004
    97
    Baltimore, MD
    I have a 73 K5 with a 6' lift on it. I do drive it on the street. I was wondering if I should eliminate the sway bar or will that hurt me in the long run. I am planning on swapping in a front 60 in the near future. Not sure if that will make any difference. /forums/images/graemlins/k5.gif
  2. rooferbret
    rooferbret 1/2 ton status
    Dec 26, 2003
    265
    Sacramento,CA
    I say remove it and see how you like it /forums/images/graemlins/waytogo.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I did just that and never put it back on. Now I have crossover so I couldn't even if i wanted to and I don't miss it a bit.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    take it off and drive it if you don't like it put it back on hey it don't cost anything to take it off or put it back on lol i took mine off and never had any regrets
  5. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I unhooked mine and its been like that for months now.
    Just take the turns a little slower /forums/images/graemlins/thumb.gif
  6. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    will it affect ride quality, say soften up a stock suspension?
  7. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I removed mine (ko tied it up out of the way /forums/images/graemlins/whistling.gif) and with the exception of drop offs on the freeway i.e. pavement changes I haven't noticed it's gone. I've even towed a small travel trailer with no qualms whatsoever.
    Good luck to y'all in the future.
    Allan
  8. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Sway bar.....what sway bar /forums/images/graemlins/dunno.gif just get ready to brace your frame /forums/images/graemlins/yikes.gif
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Take it off.
  10. 8t7jimmy
    8t7jimmy 1/2 ton status Premium Member
    Mar 2, 2004
    137
    West Lafayette, Indiana
    I took mine off when I put on a 4" lift. No regets, not much difference at all.
  11. 88Silverado
    Mar 13, 2003
    2,664
    It did for me thats why I havent hooked it back up /forums/images/graemlins/wink.gif
  12. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    do u need to do anything special to remove it?? like the ORD sway bar disconnect? or is that just so You can have it but unhooked then hook it back up when u return to pavement??
  13. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    Mine have never had the bolts in, its there just not bolted up at the axle. I rather like the ride with it disconnected. When I ran smaller tires, 35x12.5, I noticed a huge amount of sway but when I upgraded to bigger tires, 38.5x16, the sway went away /forums/images/graemlins/waytogo.gif
  14. 88Silverado
    Mar 13, 2003
    2,664
    I installed the ORD disconnects. Went out wheeling one day and disconnected the bar, decided to see how it rode back home. Been disconnected ever since. I will keep the disconnects because if I decide to tow a small trailer, etc. I will hook it back up /forums/images/graemlins/thumb.gif
  15. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    I drive mine on the street most of the time. I put in some ORD sway bar disconnects and some energy suspension greasable sway bar bushings and it made a big difference in ride quality. BTW I have a 4" Tuff Country E-Z Ride lift. Seemed to help with bump steer as well. I haven't driven with it disconnected yet. /forums/images/graemlins/dunno.gif
  16. speedyvision917
    speedyvision917 1/2 ton status
    May 5, 2004
    472
    CT
    hmmmm i think i might try that, never crossed my mind to do it
    o and steve is that really you??? lol ive seen that pic before
  17. offroadcowboy
    offroadcowboy 1/2 ton status
    Jan 29, 2004
    171
    Wittman,Arizona
    Not to hijack but... can you run a sway bar with disconnects and crossover steering on a 44? /forums/images/graemlins/k5.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/weld.gif
  18. marine_enlisted
    Sep 29, 2002
    658
    Stafford, VA
    I'm pretty sure you can't run any sort of sway bar at all with a crossover set up.
