Sway Bar Question?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by det45, Jun 8, 2000.
  1. det45
    det45 1/2 ton status
    May 23, 2000
    112
    San Antonio Texas
    Could anyone tell me where I can find a (Bolt On) Sway bar for my 1989 K5? I tried to look into aftermarket kits but most of them are for the longer axle P/Us. The K5 has a narrower/shorter axle housing. Thanks.....Det45
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Huh? Are you talking about a front sway bar?? Or a rear one? For the front, any stock one from a 1/2, 3/4 or 1 ton truck will work. As for the rear, do you mean your wheelbase is shorter, thus no long bed truck sway bars will work? Because the axle housings are the same width.
    ken
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  4. det45
    May 23, 2000
    112
    San Antonio Texas
    I'm talking about the rear axle. Yes the K5 has a shorter wheel base thus requiring an shorter sway bar. I did order a Hellwig sway bar through JC whitney for the K5 and I ended up getting a sway bar that was too long. Help!
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I'm still not sure what you mean by being "too long". Does this mean that the brackets that would bolt the swaybar to the frame don't line up?
  6. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Why would you want to put one on the rear of a Blazer? Wouldn't that hurt articulation a lot? Or is this a street only Blazer? Just curious...
    '73 K5
    Chevy good...Ford bad
  7. det45
    May 23, 2000
    112
    San Antonio Texas
    There are no brackets on the rear axle housing because my K5 didn't come with a rear sway bar. The Hellwig sway bar was too wide so I couldn't bolt it up to the axle. The rear leaf springs were in the way. If the sway bar was about 2 to 3 inchs shorter (narrow that is) I would have been able to use the sway bar. As of now I only use my K5 on the street and the skid plates have no scratchs on them. (Sad I Know) but I do not know any hard core off roaders in my area so I haven't been entised to go 4 wheeling as of yet. Did the surburbans come with a sway bar?
  8. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    I've never seen a Sub with a sway bar. I have seen 1 ton dually crewcab 2 wheel drive trucks with sway bars. I am talking about pre-'88 trucks and Subs.
    ken
  9. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    Sway bars don't use them!Hurt travel!Never seen a stock rear sway bar on a 4by.Go check out the junkyards maybee one off a 2wd will work or maybee off of a older chevy car.Brady
  10. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Need to get yourself a J.C.Whitney catalog....they have them in there for the K5...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  11. Peter J
    Peter J Registered Member
    Feb 29, 2000
    9
    Addco bar is what you want, Helwig does NOT fit right,as you've found. LMC Truck or ASI @ www.shox.com
    PJ
  12. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    They may have sent you one for an s-10 blazer.
  13. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Did you order a swaybar that was listed for an '89 pickup? A lot of aftermarket accessory companies don't have a clue that the drivetrain of an '89 K5 and an '89 pickup are not the same. There is really only 3 years ('89-'91) when the Blazers and pickups are not basically the same. Maybe try ordering one listed for an '87 or older pickup as the rear suspension and frame should be identical. This is just a thought as I am constantly fighting the guys behind the parts counters as they always try to sell me parts meant for a '90 pickup for my '90 K5.
