sway bar removal help?
Discussion in 'The Garage' started by rwright07, Feb 11, 2006.
  1. rwright07
    rwright07 1/2 ton status
    Jul 30, 2005
    536
    corporate hobo
    k so i got the bolts off from the crossmember and im trying to get the bolt off the u bolt deal, but i have limited tools n have no idea how to get this off
    help out a 17yr old lookin to get better articulation will ya?
  2. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    If its socket/driver, you'll need 1/2 drive, 3/8 will twist off. If its wrench, an open end might jump off, box end better be good quality. If you don't have enough leverage for the wrench, you might be able to slip a car jack leg (the longest part) over the wrench. Be careful, that's a big thread, and its gotten very comfortable with its rust.
  3. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah, 6 point, 1/2" drive socket is the way to go. before you get to any of that though, you should soak the darn thing in lots of pb blaster or similar penetrant. the longer it soaks, the more work it does.
  4. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    big cresent wrench withe a snipe of some sorts worked for me
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I use a big pipe wrench with a long pipe for a cheater handle... works real well.
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I think you need a 1 1/4" socket or wrench. You could double wrench by slipping the box end over the bolt then another box and over the open end of that wrench. Also, make sure you put bolts back in the forward most bolt holes where the sway bar used to mount to the crossmember. Notice how there are important crossmember braces being held on by those bolts. Leaving them out is just asking for loose steering and stress cracks. If you don't have the necessary tools, check out your local flea market or find a CK5er near you.
  7. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Xlnt reply
  8. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    mine would not come off for the life of it (tried with 3 ft of leverage and broke two 1/2 drives) so i torched it off. It looks ugly with a tortched end still hooked to the plate but it works and did not want to find new plates.
  9. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Any CK5ers out by bucksntrucks that could lend him a hand if he can't do it?
  10. rwright07
    Jul 30, 2005
    536
    corporate hobo
    thanks for the advice about puttin those bolts back in the crossmember, i woulda never thought of that il put those in as soon as i get a chance.
    i got it soakin in PB blaster for awhile n when i get back in town in 2 days il give it another shot
    ive tried using a big ol cresent wrench w/ a cheater pipe, but it barely budged... il try it w/ a bipe wrench when i get back tues
  11. divorced
    Jul 20, 2004
    5,115
    Leverage is your friend. Use the longest cheater pipe you can. It may help to drive the front up some ramps or park over a ditch to allow more swing of the pipe.
  12. prossett
    prossett 1/2 ton status
    Sep 29, 2005
    165
    United Arab Emirates
    And next time loosen all bolts instead of taking off the easy ones first - that'll keep the weight from hanging on the last darn bolt that won't come off!
    Keep working it and it'll give!!
  13. rwright07
    Jul 30, 2005
    536
    corporate hobo
    ok so i got back in town n i asked a frienda mine's dad who owns a trans shop if he could help me out n im takin that damn thing off tomarrow
    yess
  14. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    mine came off easily with a wrench and very little effort. two of the easiest bolts ive ever loosened on that truck.
  15. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    yeah I was about to say the same.I guess different trucks different circumstances.
  16. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    just gnaw on it with your teeth :D for a while. it's bound to give!
  17. rwright07
    Jul 30, 2005
    536
    corporate hobo
    done... finally
    lookin forward to wheelin soon n hopefully will notice a difference
