Sway Bar? Throw away or keep?
Discussion in 'The Garage' started by gmcjimmy88, Jul 9, 2005.
  1. gmcjimmy88
    gmcjimmy88 1/2 ton status
    Feb 10, 2005
    559
    Fayetteville North Carolina
    I am doing my front lift now and I know my sway bar wont go back on until I get drop downs/disconects. I dont want to put it baCK ON AT ALL. This thing rarely ever sees the road. If I will be flat towing it for awhile until a trailer can be afforded. Will the lack of the bar make a difference while flat towing?? Any help would be great.
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
  3. google
    google 1/2 ton status
    May 19, 2005
    805
    Arizona
    toss
  4. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    get rid of it...
  5. sweetk30
    Nov 1, 2004
    25,551
    545
    horseheads , ny 14845
    we did a pool on this over 80% dont run one. so toss it as far as possible
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Toss it.
  7. Bowtiedad
    Bowtiedad Registered Member
    Jul 7, 2005
    19
    Rochester, Indiana
    Do you still need it if it is used fairly often on the road?
  8. coreyd
    coreyd Registered Member
    Mar 24, 2004
    76
    San Mateo, CA... from South Dakota
    Lets say it's driven on the road a bunch, will the steering wonder with out the support.
  9. sweetk30
    Nov 1, 2004
    25,551
    545
    the lift springs are much stiffer than stock crap. this will take place of the sway bar. on my old truck i could take this one corner with sway bar and 31" tires at 60 no problems. same truck same corner and no bar and 4" springs 3" body and 38" tires still 60 no problems. but watch out for the much better off road flex. it will show you where you need to trim fenders in a short time.:wink1:
  10. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    Took mine off my DD with a 4" lift. Don't notice a difference at all....
    Toss it...
  11. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    went wheeling a few times with it on and it road like crap took it off and loved it, the suspension does have alot of body roll but its not hard to get used to
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the bar would limit "flex" one side to other liek when are offroading romping and going through holes and vallies and such
    withoput the bar the suspension could flex more each side of truck
    alot or not alot, depending on what springs you have
  13. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Another vote for toss it.
  14. wicked87_k5
    wicked87_k5 1/2 ton status
    Aug 9, 2004
    235
    Little Falls,NJ... North
  15. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    toss it. i left mine off when i lifted my 91 6".... couldnt really notice a difference. never had a problem. i drive daily at 65...... just leave it off.... if you dont like it you can always put it back on.... but i doubt you will. nobody does.
  16. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    [hijack]
    Ironic quote ya got there.[/hijack]
    FWIW I kept mine on the Sub, but it's mostly used for trips.
  17. gmcjimmy88
    Feb 10, 2005
    559
    thanks for all the replies. Looks like i will throw it in the scrap pile with most the other stuff.
