Sway bar ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wayne, Feb 20, 2001.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Anyone not running their swaybar on the street and did you notice a big difference on the way your rig acts without it. I know they make quick connects but was thinking of just eliminating mine if there are no serious side effects. Thanks.
    Happy Trails
    Wayne
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have been running without mine for about 2 years now. I noticed a little bit of a difference on-road. It is not that bad, it is just a little softer in the front and at higher speeds, it pushes a little harder in the corners. Nothing scary though...
    Off-road it helped out alot!!!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    keep them bad boys on if your running on the hwy if you like your truck! if you make a sudden move (dear, old ladies, etc) you could roll it. Get some disconnects for them. It's just not safe on the road without them.
    [​IMG] Keep your feet dry [​IMG]
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You probably will hardly notice that the sway bar is disconnected... until you need it most. In an emergency maneuver it could mean the difference between a quick, scary swerve and losing control of your ride. [​IMG] The disconnects from ORD are pretty cheap and provide the best of both worlds. You still get decent handling on the road and maximum flex off the road.
  5. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    If you have stiff lift springs, you will never notice that he sway bar is missing. I have removed all three of them on all three of my rigs equiped with sway bars. One is a 6" lifted Suburban, the other a 10" Superlifted dually crewcab with a 9.5' Lance cabover camper, and the other is a National spring 12" lifted Suburban. I don't even notice...well OK, on the camper a little!!
    ken
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    The biggest thing I noticed with stock steering was that the steering was a tad sloppier, it seems the sway bar helps to locate the axle. I ran it this way for a couple years, I disconnected/reconnected it a few times, then I got lazy. No big deal really. I drove it quite a bit in town back then, I used to deliver for Dominos (w/ a 4" lift, winch, and 35s). With the crossover, I didn't have a choice. Steers great now.
    The older trucks never came with a sway bar. I think they started in '73, but I know my brother's '70 never had one.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  7. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i knwo this is a dumb question, but i wanna know.
    where is my sway bar? and how do i disconnect it?
    i wanna test my flex w/out it!
    <A target="_blank" HREF=http://www.geocities.com/confederatek5/>http://www.geocities.com/confederatek5/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  8. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    Swaybar? You don't need no stinking swaybar!! I tried ORD's disconnect and found them to be a pain in the a$$.So I took it off and haven't looked back.Brady
    '73Beautiful Disaster <A target="_blank" HREF=http://beautifuldisaster.coloradok5.com>http://beautifuldisaster.coloradok5.com</A>
  9. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Thanks for the info. There is alot of difference of opinions on this subject. I guess once the lift and everything else is done I will remove it and see how it feels. I didn't want to run quick connects because of what I heard about them being such a pain, but I will if I have to.
    Happy Trails
    Wayne
  10. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Confederate9 were you serious? If you were the swaybar is in front of your front axle. It is the bent looking bar that goes from one side to the other and is connected with two brackets to the frame. (One bracket on each frame rail.)
    Happy Trails
    Wayne
  11. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    like i know where it is kinda, but i need to know where exactly to disconnect it.
  12. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Confederate9 it sounds like you need some help. I read your bio and was wondering if you did the lift yourself or had it done. As far as disconnecting your swaybar just follow it to the ends and unbolt it and then unbolt the frame brackets. I would reccomend you go to your local parts store and buy a repair book that covers your rig as that will help you with future work.
    Happy Trails
    Wayne
  13. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I prefer the ride WITH the sway bar attached.
    I have the ORD disconnects so that I could retain the sway bar with a 6" lift.
    Keep in mind that just because you CAN disconnect the sway bar using the disconnect, you don't HAVE to. It is a pain in the butt to reconnect. Do you really need that last little bit of articulation every time you wheel? You've been doing just fine with it connected this whole time.
    Just a litltle rebuff to everyone who says how hard it is to reconnect.
    -- Mike
