Sway Bar
Discussion in 'The Garage' started by mrcold, Apr 17, 2005.
  1. mrcold
    mrcold Registered Member
    Jun 6, 2004
    37
    North of SWEDEN
    I'm about to install a 6 in suspension lift and I was wondering what to do with the front sway bar... with a 6 in lift I'll have to remove it right?
    What will it do to the truck... will it be mutch harder to drive? Can i do someting to be able to keep it on besides going for a lower lift?
    EDIT: I'm driving a 86 blazer with 10-bolt in the front.
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    do a search youll find lotts of info
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your adding a 6" lift spring which has a higher arch and a higher spring rate then your stock springs. Don't worry about it. Through that heavy piece of crap in the trash and forget about it.
    Harley
  4. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    what sway bar ? mine was gone a long time ago. and it felt o.k. to me. i ran 6" and 3" body with 38x12.50x16.5 and 25psi and no big problems.
  5. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    pull it, be carefull when you first drive it and take corners... change your cornering speed accordingly. Depending on how stiff you front springs are, you may not notice any difference at all...
    j
  6. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    Hello!
    för F*n , jag trodde jag var den yngsta i sverige som körde Blazer..kontakta mig , ICQ , MSN , Mail
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    just make sure you ALWAYS have good shocks on it with the bar off. One bad shock and it's gonna feel very tipsy...
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    could always make drop brackets for front of bar..
  9. mrcold
    Jun 6, 2004
    37
    North of SWEDEN
    ok, thanks for the help.
  10. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    ord also has relocation/disconnect kits
