Sway Bar
Discussion in 'The Garage' started by TC4x4, Nov 22, 2006.
  1. TC4x4
    TC4x4 1/2 ton status
    Sep 12, 2006
    831
    Michigan
    What Will Happen If I Take The Sway Bar Off?
    Will I Get Any More Lift, I Know That It Will Help With Articulation But Is It Good Or Bad To Take It Off, Can I Still Cdruve On The Road Every Day With Out It? Thanks Yall
  2. djsblaze
    djsblaze 1/2 ton status
    Jul 7, 2003
    318
    Oklahoma
    Not going to give you any lift, at all. I took mine off a few years ago and never looked back. If you have aftermarket springs, my guess is they are stiff enough to compensate for increased body roll. If you have stock springs, you might be leaning a bit in the corners...
  3. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    You can take it off. I just took mine off and I still take corners fast and I have a 4" suspention lift. So far I dont feel any diffrence in my Daly Driving.
    So I say if you have a lift under your truck TAKE IT OFF and FORGET about it.
    Or get the ORD disconnect kit
  4. TC4x4
    Sep 12, 2006
    831
    Michigan
    what advantages does it give you to take it off /
    thanks guys
  5. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I can say it does inprove articulation.
    Thats about all I know.
  6. TC4x4
    Sep 12, 2006
    831
    Michigan
    thanks guys
  7. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    The axle falls off.
    J/K
    I took mine off about a month ago. I have a 4" lift. I was concerned at first because I had some increased body roll. I'm used the body roll now I am scrapping it. It's riding a little smoother overall. My springs are pretty stiff.
    The common theme is try it off and if don't like it put it back on.
