Sway Bar
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DMK, Jun 22, 2000.
  1. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Does anyone run without a sway bar, can you tell a difference? Thanks.
  2. Big B
    Big B 1/2 ton status
    222
    fort worth texas
    i run with mine disconceted (sp?) and yes you can tell it is real lose with it off , but i never drive mine on the hi-way only back roads to the trails if i dont put it on a trailer , i would be to scared to drive at hi-way speeds with t of but you have to make that call . hope i helped Big B.
  3. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    I have all 3 of mine off on my 3 rigs. I can't really tell the difference, although my Sub with its new 12" National springs is a little "lean happy" going around long sweeping turns (like freeway on ramps). I guess it all depends on how soft your springs are (especially the fronts). If they're too soft, you'll need a swaybar. 10" Superlift springs are not soft in any way, so without a swaybar, there is no difference.
    ken
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have had mine off for about 2 years now and I cant tell the difference.
    Mike [​IMG]
    1982 GMC Jimmy - <font color=green>Emmett</font color=green>
    http://emmett.coloradok5.com
  5. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Thanks for all the replies.
  6. Eagle
    Eagle Registered Member
    72
    Suprise, AZ
    You will get a ton more flex up front. But if you remove it make sure you check that your U-bolts are tight.
    There is a VERY fine line between hobby and mental illness
