SWAY BAR
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 72GMCJIMMY, Mar 11, 2002.
  1. 72GMCJIMMY
    72GMCJIMMY 1/2 ton status
    Mar 17, 2001
    142
    I have a front anti sway bar from a 73 to 79 Chevy on my 72 Jimmy. I need new bushings and can't find the ones that go into the end of the axle side of the sway bar. I can find the frame side no problem. The bar is 1 1/6 inch diameter. Does anybody know where I can find them?
    Thanks Rich
  2. Grim-Reaper
    7,385
    Atlanta
    http://www.offroaddesign.com can set you up. I know Energy suspension sells them because I have bought them twice. If you need just the ends then Stephen at ORD can probably set you up. Becides you need the ORD quick disconnects /forums/images/icons/smile.gif
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    I just went ahead and ditched the sway bar. Just limited my articulation. I really couldn't tell a difference with it off going down the road. I dont really know your situation though.
  4. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    Sway Bar? Whats that? Just kidding, I ditched mine also. But I rarely use my K5 for the street.
  5. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Rich,
    I just ADDED a swaybar to my '72....got all the replacement bushings and quick disconnects from ORD. The only thing that sounds "weird" is that your bar is 1-1/8" diameter. I think that like 99% of them were actually 1-1/4", and only a small fraction were the smaller size.
    I'm not sure if that will change the bushing sizes you'll need, but you might want to double-check your measurement just to be sure.
    FWIW -> The swaybar made a HUGE difference for me. I had body roll with my softer springs, but I added the sway bar to cure "BUMPSTEER" which was my primary concern. It did a great job of almost completely eliminating it!!! /forums/images/icons/cool.gif
    That experiment saved me the expense of doing crossover steering (~$1000) which I really didn't want to deal with yet.
  6. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Just a side note to the posts on ditching your swaybar:
    If it is strong enough to limit articulation logic would assume it would do a good job preventing sway and body roll. But if you have stiff lift springs up front you probably could run without the sway bar and not feel the difference. I run mine on my daily driver and disconnect it when I need to. It feels tighter in turns. But its all personal preference.
  7. 72GMCJIMMY
    Mar 17, 2001
    142
    Thanks everyone, Rich
