Sway bar
Discussion in 'The Garage' started by 91k5NC, Jul 13, 2002.
  1. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    do you have to leave off the sway bar when putting on a 4 inch lift? /forums/images/icons/confused.gif
  2. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    no you can still run your swaybar if you want to.. i still ran mine when i put in my 6" lift, i had to use some brackets to lower it though , and i'am sure you'll need some also... But i took it out after i put in a crossover steering setup.
  3. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Mine is still in there, and I have a TALL 4" lift, had a helluva time getting it to line up again though /forums/images/icons/grin.gif
  4. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Try the ORD swaybar disconnects. The are also a correction for the lift. You can cruise the hiway with the bar hooked up and when you put it in the dirt you disconnect the bar and swing it up out of the way...
    Jim
