sway bars
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by huggerk5, Aug 27, 2001.
  1. huggerk5
    huggerk5 Registered Member
    Aug 16, 2001
    25
    Amarillo, Texas
    I've never even considered sway bars until reading this sight. Can anyone give me some insight, pros, cons and trouble they had in the process?
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    It does get rid of the sway, making it more driveable in the freeway. specially down narrow roads. i travel a lot to mexico and some of roads are very narrow with no shoulders. some of my first driving experiences where not fun. i had to slow way down whenever i saw a BIG F truck coming the other way. swaybar made a hell of a difference in stablility. This all with a stock 72 4x4 blazer, 31x10.5, with rancho 5k shocks.
    Others have not noticed much of a difference, specially with stiffer suspensions.
    anyhow, i put one in from a second gen blazer(77blazer). Go for the 1-1/4" swaybar if you are going to do it. you will need the front leafspring caps that hold the swaybar. as for the mounts that mount on the frame. I had to reverse the brackets(left on right, right on left). With a lift you may want to go with some disconnects, that's one of my next "future" projects.
    you may also get some imput from:
    Steve Chin(fabed his swaybar mounts) and
    Burt4x4(had put in an aftermarket swaybar kit)
    later,
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    The front bar made my Blazer much more driveable on-road. I didn't disconnect it at Blazer-Fest and the Blazer seemed to weenie-wheel (I am too much or a rank amateur and coward to do any of the crazy stuff) just fine. It is much flatter cornering than it was and the adhesion limit is higher. It introduced a bit of understeer, so I am thinking of fabricating a rear bar to compliment the front one.
  4. Max
    Max 1/2 ton status
    Feb 19, 2000
    158
    Durham, NC
    Let me know if you are interested in a sway bar, just yanked one off my 71.
