Sway Bars?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Dune_Goon, Sep 4, 2001.
  1. Dune_Goon
    Dune_Goon Registered Member
    Mar 9, 2001
    55
    Santa Maria, CA USA
    Does anyone know of, or have a set of sway bars for a first gen? Mine get's rock'n real bad on the freeway and needs a set of sway bars. Where can I buy um? Anyone have a set or just one that they want to get rid of? It's for a 1972 GMC Jimmy, 4x4, 350x350xNP203
    Cameron Gunlock AKA Dune Goon
    addicted2dunes@hotmail.com
    www.Pizmo-Dunez.com
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i don;t think our gen came with sway bars. I modified one to fit from a 2nd get blazer. get the 1-1/4" sway bar. It's not that bad of a adaptation. there are some people who have done this I used the 2nd gen frame brackets but i had to swap them(put the left on the right and the right on the left). Steve Chin fabed his own brackets, i think he has some pics. Burt4x4 has an aftermarket swaybar. I can send you some pics if you want just let me know.
    ARQ.
    oh yea total cost was about 60 with new bushings and 1/2 days work.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer<P ID="edit"><FONT class="small">Edited by arq on 09/04/01 11:19 PM.</FONT></P>
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yup I think it is Addco brand. duno if I spelled that right? I bought it back in 95ish so can't remember realy what I paid. I had to dril two holes per side into the bottom of the frame rail and the bottom of the sway bar bolts to the spring pack. Well I have 5" disconnects inbetween the bar and springpack to keep the bar level. I would get one probly cheaper to just fab the second gen bar and you can get disconnects too!!
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  4. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    Using Gen2 brackets, did you have to pull the front crossmember? I am gettting a complete Gen2 front crossmember, for the brackets, but am considering just replacing the stocker crossmember. You have any pics of your install? Any ideas? Thanks
    JB
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    i did not have to replace the cross member. i do have some pics, i'll post them later today.
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Check my web site for some pix of my installation:
    [url}http://www.geocities.com/MotorCity/Downs/1963[/url]
    I'm also using a Gen2 front bar. The Blazer now corners flatter, but it is tight, so I am looking for a good design of rear bar (not finding one). If I don't find one in a reasonable amount of time, I will probably fab up my own rear bar.
  7. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    here they are
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>http://coloradok5.com/gallery/ArqDennis</a>
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
