Swaybar Disconnect Suggestion
Discussion in 'OffRoad Design' started by rcamacho, Dec 21, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Stephen, et al
    I've recently had to completely disassemble and grease the disconnect kit after several years of use. The assembly would bind up completely when torqued to spec. It might be a nice convenience item to offer barrel drilled bolts with zerk fittings so they can be lubed in service.
  2. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I need to agree with this one. I've run across a couple of these that were rusted solid.
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
    Fixed. Apparantly the PO assembled the disconnects dry. I've lubed them up and have drilled them for a zerk fitting. The latter appears to be very straightforward provided the swaybar movement is taken into account. I've positioned the zerk towards the rear of the vehicle so it can not interfere with the swaybar.
