Swaybar disconnecting with less than 4" of lift?
Discussion in 'The Garage' started by sled_dog, Feb 14, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Swaybar disconnecting with less than 4\" of lift?
    I doubt the ORD kit would work below 4" of lift or at stock height so anyone have ideas? Thinking a custom disconnect setup. I want to work on the burb and make it flexier. I may go to 4" of lift but I'm not quiet sure yet, probably use my 4" BDS springs that are on the buggy when I do a 3 link up front.
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Re: Swaybar disconnecting with less than 4\" of lift?
    I dont know why it wouldnt work /forums/images/graemlins/confused.gif
    Had mine on my truck before I did the lift.
    Mayme post a message in the ORD room /forums/images/graemlins/peace.gif
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I did a 4" lift on my Burb and was concerned before the install that it would be too high, but i was wrong, it is actually perfect and i'm still runnin stock 31/10.50 tires too.I believe after the 33/12.50 tires go on it will be just right. /forums/images/graemlins/waytogo.gifI believe you'll like it with the 4, it's not outrageously high to where it's not versital for everyday use, but gives the extra ground clearence needed for better wheelin. DO IT,,, /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I don't plan on wheeling the burb much, just some poser crawling, and looks, but I will build it to be capable and not just a poser rig. I think I will wait till I can afford the King Coilovers for the front of my buggy then move my 4" bds springs to the burb.
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I don't have the ORD disconnects but I unbolt my sway bar when I'm wheelin'(it's much cheaper). I have a stock height K5 and it does wonders for the flex...
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I unbolted mine... and threw it away! /forums/images/graemlins/grin.gif
    I have 150" wheelbase though.... might be more beneficial to handling on the shorter rigs.
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i used to unbolt mine, then got sick of trying to get it perfectly level when i wanted to hook it back up. much easier with the ORD discos. worth every penny. and yes they work perfectly fine with a stock lift.
  8. tRustyK5
    Jul 23, 2000
    36,167
    1,364
    E-town baby!
    I chucked mine too...and it handles just fine. My wheelbase is approx 108". 23 lbs of junk IMHO.
    Rene
