swaybar question/idea
Discussion in 'The Garage' started by sandawgk5, Apr 1, 2004.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    We all now with x-over steering we lose the ability to use the factory sway bar. So my thinking or idea if you will is if you have a super flexy rig that does see street time and there is a need for a swaybar why cant we use the NASCAR style of sway bar and use QD's to disable it while offroad. If I am totally missing something here let me know. It is just a thought I have been having. /forums/images/graemlins/burb.gif+ /forums/images/graemlins/hack.gif= /forums/images/graemlins/crewcab.gif
  2. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    the problem arises with cross over is that the sway bar won't work with the drag link going across to the passenger side someone correct me if I am right ....Jason
  3. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Ko help out us folks that apparently don't pay enough attention to the cut away car on tv to know what the Nascar style is. Good luck to ya in the future.
    Allan
  4. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I'd be very interested in a setup like that. I haul a lot of crap with me to Nevada from Cali and the idea of doing the asphalt twisties absent a swaybar doesn't exactly blow my skirt up.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You mean torsion style sway bar. When off road unlimited does a straight axle swap, thats what the truck gets. I would assume it works with crossover steering, as thats what those trucks get. The bar would bolt on to factory frame mounts, and have splined ends. The links will run from there to axle ends. I believe disconnecting it will be as simple as loosening the clamps on the end of the bar. Of course it will need a little working, but any CK5 guy can figure out how. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  6. sandawgk5
    Oct 28, 2003
    6,881
    Ya I guess that is the technical name for it The first place that I had seen that type of sway bar was on the rear of a NASCAR WINSTON cup car. /forums/images/graemlins/dunno.gif<=Air Force salute /forums/images/graemlins/grin.gif
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you look here Straight Axle Swap you will see the sway bar that these people put on the trucks they build. I wouldn't pay them to do any work, but the swaybar pic should give you an idea. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  8. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Nice postage stamp picture they give you to see it. I better eat four dozen carrots and get some normal sleep then I might be able to view it with an atomic microscope. Where in the heck did they bolt it?
  9. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif
  10. justhorsinaround
    Sep 16, 2003
    6,798
    I spect that'd prolly do the trick that you're lookin for. It mounts in the stock holes and it gets the bar up and out of the way with those arms and linkages. As far as quick disconnects, one would think that undoin the two bolts at the axle wouldn't be that difficult. Good luck to ya in the future.
    Allan
