Swaybar, removal or relocate?
Discussion in 'The Garage' started by Ronnie4wd, Nov 2, 2003.
  1. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    With a 4"lift what do you /forums/images/graemlins/thinking.gif?
    I use my K5 both on and off road.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Whick springs are you running up front? I run Superlift and they are stiff enough that I run no swaybar without any ill effects /forums/images/graemlins/thumb.gif No swaybar really helps out suspension articulation try it and see how it handles.
  3. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    Thanks I think I´ll try without it .I don´t know what springs it is but they are real stiff.Don´t think it´s street legal here in Sweden without it /forums/images/graemlins/crazy.gif but who cares /forums/images/graemlins/ignore.gif.
  4. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Ditch it and don't look back. The swaybar is usless. I run fairly soft springs up front (BDS) and my Jimmy rides just fine. My suspension setup is: 5.5 BDS ALL-spring suspension & 1" ORD Bodylift on my 37's it I have noticed nothing drastic in how the Jimmy handles without the swaybar.
  5. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    yeah, try and run ur rig a week without it onroad and see what you think. Only problem i can forsee is if u had Tuffcountry ez rides... spring rate is sooo low on them u might be taking corners at 2.5 mph and still feel like ur gonna roll. /forums/images/graemlins/wink.gif
    j
  6. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    As long as you take all the mounts off and try to make it look like there wasnt one ever there, i dont think theyll bother you.
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    ORD disconnects!
    They will compensate for the lift as well as allow you to disconnect it when you go off road...but you will still have it for the drive back on those twisty mt. roads.
  8. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    Thankyou for all the answers.I went the cheap and fast way:removed and thrown in the corner for future use,went for a short ride and couldn´t feel any difference /forums/images/graemlins/thumb.gif.
  9. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    Don't try to corner like a sports car or an idiot and you won't need it at all.
  10. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    ORD disconnects!
    Agreed! 4" BDS springs up front, BIG difference on country roads (AKA Indiana Highways)
    I had the sway bar connected direct and it was OK
    Took off the sway bar... Not a fun ride
    Installed the Disconnects... WORLD of DIFFERENCE! Even better than the sway bar connected direct to the spring plates /forums/images/graemlins/deal.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah cause that bar binds like crazy in a lifted truck without the disconnect. I can't wait to ditch mine.
  12. Highjaxx
    Highjaxx 1/2 ton status
    Apr 17, 2002
    273
    Austin,Texas
    I pulled my sway-bar off to get used to it, looking forward to putting my D60 on w/ crossover.
    I accidently left my Rancho 9000's dialed to "2" for about a week after offroading, and it was SCARY. /forums/images/graemlins/eek.gif
    After I realized my shocks weren't set right I dialed them up to "4". Now I really like how it rides. The front is softer, and takes bumps better.
    It did increase body roll, but with the shocks turned up it is tolerable.
    The sad part is that the front is stiffer than the back. /forums/images/graemlins/thumb.gif
