Swaybar Removal - your Thoughts?
Discussion in 'The Garage' started by prossett, Oct 12, 2005.
  1. prossett
    prossett 1/2 ton status
    Sep 29, 2005
    165
    United Arab Emirates
    New to GMC - quick question, quick answer: how does removing the swaybar permanently sound to you guys?
    On my Wrangler I took it off and had no bother at all, but looking at the '83 Jimmy front suspension the axle is mighty close to bottoming out (in fact both my bump stops are shredded), plus it's a big hefty truck to drive around without swaybar on.
    I mostly drive on sand, tracks and dunes, and maybe 5 mins on slow city road daily.
    Reason I'm asking is both frame bushings have completely disintegrated, and it's now metal on metal. Must either put in new bushings or remove.
  2. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    without stiff lift springs, I wouldn't consider, even for exclusively off road. I've got the disconnect on mine to take it off off-road As you say, these are big heavy trucks and roll considerably even with the bar.
    You can see that they are shredded from use, the truck rolling side to side constantly. Bushing install is worth the effort.
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    when I had a d44.. I had mine in.. wheeled all the time... went to a d60 which came with the swaybar too... couldnt get it to line up on my drop brackets... so took it off and havent put it back on. I always said to keep it but now a firm believer that ya dont need it :crazy:
  4. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
    I've just taking the swaybar off of my suburban and it rides a lot better. I have 6" superlift springs though and they are very stiff.
    If you have a lifted truck i would definetly recomend it.
  5. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    Sway bars are OVER-RATED IMHO :D
  6. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    if your running stock springs your probably gonna notice it quite a bit. But take the 2 bolts out of where they bolt to the Ubolt plate and drive it if you love it take it all the way off if you hate it put the 2 bolts back in... if you cant decide leave it hanging till you can :D
  7. prossett
    Sep 29, 2005
    165
    Yes, sir, that's gotta be the right answer! I guess it depends so much on driving style and springs condition - I was just wondering if everyone would say: "Are you crazy? Jimmy with no swaybar = certain breakage of both car and bones".
    I'll try it and let you know how it feels with my stock springs...
  8. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    haven't had mine in for years. yank it and forget about it.
    j
  9. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    I ran ano sway bar on stock suspension (3/4 ton) and barely noticed it was gone. unless it was really windy i couldnt tell.
  10. 79k20350
    Nov 22, 2004
    7,757
    Ct
    also if its stock height, you cant run dissconnects anyways
  11. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    took mine off, ( 4 inch lift, 34 inch tires ) the only time i miss it is rough spots or railroad track crossings at freeway speeds. Little spooky sometimes, but no way I'd hook it back up. way more flex and quite a weight savings. And it's street driven every day.
  12. scubahard
    scubahard Registered Member
    Nov 3, 2004
    47
    California
    stock springs and stock height - Keep it.
    aftermarket lifted springs - remove it.
    The key thing is that you do not want to bottom out if your stock springs are really worn out and you have no bump stops.
  13. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i had one in the front and the back...took em both off and will never put them back on...
  14. mtnman
    mtnman Scrap metal fabricator Premium Member
    Sep 8, 2005
    2,087
    31
    On the farm , Missouri
    Sway bar
    Throw it away - cut it up - make art out of it - chucked mine nearly 20 years ago, ripped it off of every 4x4 of mine and several of my friends' since then!!! A useless hunk of iron IMHO :D
  15. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    i realy never noticed any drawbacks. people tent to comment on it missing though. i figured the 67-72s didnt have them why should the 73-87 need them
    balzer
  16. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    Exactly, I took mine off and drive it on the road 3-4 days a week. I think rides better without it. It definitely rides better offroad without it.
  17. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I have a 1-ton crew cab with 6" of lift, and I just took mine off today. The truck feels like it is going to roll over when I go into any turn on the street at even a reasonbly slow speed. Mine is going back on.
  18. mtnman
    Sep 8, 2005
    2,087
    31
    You'll get used to it in time, and be glad it's gone!!!! :D
  19. slowk5
    slowk5 Registered Member
    Oct 14, 2005
    72
    gladstone oregon
    I lost mine when i went to cross over. cant rally the turns as fast now. but it sure flexs better.
  20. mciahpv
    mciahpv Registered Member
    Jul 8, 2005
    97
    Gator Country
    Had never really given it a second thought before, but after reading all the posts, I did some testing on mine, both hooked up and unhooked on the same stretch of road.
    The ride was MUCH smoother when disconnected, and I couldn't feel any noticeable tendency to roll when cornering, etc. Of course, I'm running on 12" lift springs, so I don't know if my experience is necessarily what everyone can expect.
    Anyway, the sway bar is on the way to the junkyard and I'm much happier with the ride.
