Swaybar removal
Discussion in 'The Garage' started by grindkings, Dec 30, 2004.
  1. grindkings
    grindkings 1/2 ton status
    Dec 24, 2004
    127
    Marshall, Missouri
    How do i get the large bolt that holds the sway bar to the leafspring off?
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    If it's being stubborn use a breaker bar.If you don't have a breaker bar slide a piece of pipe over the handle of the socket so it extends the handle and gives you better leverage.
    try spraying with some penatrating oil as well(WD40).
  3. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    man...theres really no room for a breaker bar......and they do turn just like anyother bolt right?
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Take the tire off.Lot's of room then.
    Ya,turn it counter clockwise to loosen it.
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Righty-tighty...lefty-loosey.
    I used a 2 foot breaker bar when I undid mine.
    Rene
  6. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    well....i'm not talking about the leaf spring bolts..the sway bar bolt is vertical so the cheater bar would be hitting the under carage.
  7. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Yeah, they turn just like any other bolt. Just spray a lot of pb blaster on it and keep going at it. If you have access to an impact wrench, they seem to work well in that situation. I know there is very little room, but when I took mine off I had to use a piece of pipe over the end of the wratchet. It would only turn one or two clicks every time, but at least it worked. Just keep giving it hell.
    -Harrison
  8. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Are you talking about the drivers side bolt?
    It doesn't matter really,there's still room for a wrench.Like posted above,it may only be able to turn it a click or two at a time but you can still get it.
  9. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    both passanger and driverside.
  10. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    try putting some heat on it
  11. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    awsome guys.. POPED right off..Thanks for all the help.
