  1. rescuekrawler
    rescuekrawler Registered Member
    Nov 7, 2004
    28
    Can anyone tell me the best way to make or can I by swaybar disconnects.
    anyone????
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Just take it off...If you aren't sure about that then I would recommend taking it off for a week and see how you like it, most people never look back. If you decide you have to have disconnects, ORD sells them.
  3. barryb
    barryb Registered Member
    Oct 15, 2003
    51
    Springfield MO
    i agree, when i bought mine, it had front (sways)and the previous owner had installed a rear swaybar, trying to avoid the body rolls and after i put on a 4 inch lift - pulling the 14 year old worn out factory springs - the blazer has so little noticable sway - even though it was a higher, a lifted vehicle - it had less sway- it feels better than it did before i started the project ...
    ps. i noticed when i am drinking i just put the "-'s" and the ",s" where ever i want ...........
  4. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    I noticed zero difference when i removed mine for good. Just ditch it, you dont need it.
  5. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i notice when mine is disconnected. if you drive like a grandma then it would be fine, but take a hard corner and i can sure feel it. it also depends on how soft your springs are. another thing to consider is wheel width and tire size. with my 33" BFG a/t on 8" rims i can feel the tires roll over in corners. with my 33" tsl on 10" rims i notice less body roll in a corner, even tho they are bias.
    so i think if you have fairly wide wheels you'd miss the swaybar less.
  6. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Cut it out like the flex cancer it is
    When I took mine out, it was the best flex improving mod I had done
  7. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    I drive like anything but a grandma. With bias ply TSL's that measure 36x10.5 mounted on 5.5" wide rims, the tires roll over and the body leans no matter what. I felt zero difference when i removed mine.
