Swaybar
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Z3PR, Jun 20, 2002.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Forgot to get a drop kit for the swaybar, so didn't put it back on when finished the 6" suspension lift this evening. Does anyone see any problem running without one ??? /forums/images/icons/confused.gif
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Should be fine , lots of people toss them.... just have a little more body roll when cornering.... /forums/images/icons/wink.gif
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    when i put my 2.5in lift in i didnt put it back on and have no regrets(sp?)
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    No problem running without it. If you decide that you want to keep it I would recommend that instead of the drop kit you buy the ORD disconnect kit. Best of both worlds, you can disconnect it for more articulation and it also allows the proper movement since you lifted the truck 6"
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Leave it off. I have the same springs as you (6" Superlift Softride), when I first put on the lift I put the sway bar back on and it rode real stiff. I pulled it off to try and gain some flex and not only did it flex much better, but it rode 100 times better too. I've never wanted to put it back on since then. </font color>
  6. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    Depends on how you intend to use the truck. I like to head up north in the winters and this means sometimes icy conditions at freeway speeds. I wanted as little body roll as possible, and running without a swaybar was not an option. The disconnect kit allows the best of both worlds. They can be a pain to reconnect though if you are not on a totally level surface, or by yourself.
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    Good point, I have the disconnects and it is easier if you carry a hammer to tap things back into position, or a rock hehehehe..... /forums/images/icons/smirk.gif
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I really don't plan on much interstate driveing when the roads get icy, Everything I need during the winter is with in 12 to 20 blocks from the house anyways. But I'll probley get the ORD dissconect kit befor winter hits to be on the safe side. /forums/images/icons/smirk.gif /forums/images/icons/tongue.gif /forums/images/icons/wink.gif /forums/images/icons/grin.gif /forums/images/icons/cool.gif
  9. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Haven't had it on for about 6 months now. No problems other than high speed turns and wind gusts. /forums/images/icons/grin.gif
