Swear word: Car wash
Discussion in 'The Garage' started by Janitorjim8, Dec 17, 2005.
  1. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    So i know many of you probably don't wash your truck all that much, seeing that they are for go not show most of the time. I am starting this tread because i am big into the mud and wonder if you guys have any secrets about getting mud off the undercarriage. Same applies for salt under there, i am trying to wash the blazer every other week this winter to get the salt off there. Nows when i wish she fit through car washes lol. My favorite trick is front wheels on the curb, gives me more room to lay under her and wash it.
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Well.. not sure how well this will work up north at this time of year... but, some guys throw a sprinkler uner the truck and let it do the underside for them.
  3. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Sprinkler??..HA!..not here...
    A sprinkler would turn my driveway into a nice skating rink tonight!--its 23 degrees here now!..our "mud" here is mostly clay..I bought my 74 K20 from an "Off Roader" who buried it quite a few times in the clay,judging by the amount of concrete looking clumps that were so firmly adhered to the undercarriage it took hammer blows to break it off!..
    I had that truck since 1990--I washed the thing a hundred times,even used a pressure washer on it once!..I never succeeded in getting all the clay off the firewall where the tires had flung it!..stuff was like mortar,not mud!It was still there when it went in the crusher this July!....I sincerely doubt a sprinkler will remove much of the "mud" we have here..other states and places ,--maybe..depends of what type of dirt..
    I'd say high pressure,and HOT water with soap is best..even the car washes here,which had decent pressure and hot soapy water,didn't seem to phase the mud on my truck though..a Steam Cleaning might have done the trick..either that or sandblasting..:wink1: ..
    I read somewhere in an off roading book if you apply liberal amounts of Linseed oil to the frame and underbody,it will keep mud from adhereing so well..supposedly keeps rust at bay too,and lasts quite awile before you need to apply it again..many guys around here use drain oil on their trucks frames and undersides..it works,I've seen several "oldies" that are still in great shape,despite daily use in salty winter weather..
    I think Deisel engines used oil is best--the soot makes it cling better to the frame,and doesn't wash off easily..one local garage made a habit of disposing of the used oil on his customers cars by spraying the underneath of their cars with it!..all the grandmothers with their 30+ year old Impala's and Buicks had mint undercarriages in their cars that went there for service..:crazy: ..
  4. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    At one of my wheeling spots we would just go through a water hole that was deeper than the floor pan and drive forward and reverse a few times after wheeling in the mud and it would wash the undercarriage clean leaving most of the outside covered for that mudder look in town
  5. fasthumpman
    fasthumpman Registered Member
    Oct 22, 2005
    85
    Texas
    im with the sprikler idea but i usually drive mine on some rocky trails after my mud has dried and it vibrates all the big sh|t off.
  6. drofdar
    drofdar 1/2 ton status
    Dec 7, 2003
    113
    Fresno, CA
    Down in Baja lots of buggies and 4X4s get run through the salt water on the tide flats. A grizzled Baja old timer once told me the key to salt corrosion prevention was to get a lawn weed sprayer and coat everything with turpentine. Don't know if it would help at cleaning time, but would be worthwhile to try if you're gonna be under there anyway!
  7. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    pressure washer.................
  8. 350k5
    350k5 1/2 ton status
    Feb 15, 2005
    115
    Bloomington, IN
    Take it to the car wash but don't go in the drive through. Find a car wash that has one of those ports you can drive into, you put in some quarters and pressure wash what you want cleaned yourself. Going through the actual car wash won't get the undercarriage, at least not enough to get caked on mud off of there. I spent about 3 bucks in quaters and got everything underneath cleaned off. That's what I'd recomend.:o
  9. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Buy several cans of Pam cooking spray. Before you go mudding, spray the entire undercarriage with it...................
  10. Janitorjim8
    Feb 21, 2005
    215
    Illinois
    i usually go to those ports at the car wash, because its not worth cleaning off the rediculous amount of mud that would be on my driveway if i used the power washer here. Sometimes i will spray wd-40 or Tire Wet spray in my wheel wells, that seems to work pretty well
  11. MOBK5
    MOBK5 1/2 ton status
    Apr 5, 2005
    180
    MCAS Cherry Point, NC
    I had a horrible power steering pump leak for the longest time and ATF got all over the driver side leaf, tierod, draglink, steering box, everywhere. One day I went mud riding and the mud got all over the underbody and when I got home there was none in the area that was saturated with ATF.
  12. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    cheaper and easier go buy a gallon of vegetable cooking oil and put it in one of the pump weed sprayers and do that. i used to put it on my tires back when i had crappy ones and i need all the helpi could get.
    worked well on teh underbody also.
  13. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
  14. gmcman7202
    gmcman7202 1/2 ton status
    Sep 19, 2005
    181
    The land of FIBS
    i am not sure abou this, but i heard one time that the drive through car washes reuse the water, just filter it a little. just think of all the salt in the water if thats the case, in winter that is....
  15. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    There you go...:D Been doing this for years.Even shoot the bed of the dump truck when hauling hot mix,works great.
  16. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    One thing I did was trim the lip on the inside of the fenders. Leave as much of the part that runs para to the ground as you can for strength, but the part that runs up and down gets cut off. The coat the inner fenders with gloss black paint. You can spray it with pam so it doesn't stick at all, but I'm usually able to get all the muck off with a garden hose and nozzel. Works good.
  17. 6.2puller
    Jul 8, 2004
    569
    New England
    I know this is true in atleast some cases. They have a huge filtration system under the one that I use and it filters the self power washer section also. I use it for getting the big debri off and the majority of the salt but it definatly doesn't replace a good hand wash and wax if thats what you are after.
  18. sandracer799
    sandracer799 1/2 ton status
    Feb 10, 2004
    834
    Richmond,Virginia
    When i wash the underside of mine I usually pull it on a trailer so i can get to the underside easier. Just lots of time and a pressure washer is the best way i have found to get the underside clean. And always clean it after you have gotten it dirty that way there is not alot of build up and it comes off easier.
  19. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    where are you from in IL i live near chi town
  20. Janitorjim8
    Feb 21, 2005
    215
    Illinois
    Pro junk racer im from Libertyville, about 45 minutes north. Do you have a lot of places to wheel by you?
