swerving ?
Discussion in 'The Garage' started by NEK5, Mar 19, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ok i think i`ve narrowed it down to this...could having my tires at 20psi be the cause of my swerving in and out of the lanes around 50mph on the highway?
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Yes, that (low or uneven tire pressure) is one possible cause of "poor directional stability". Also bad shocks, ball joints, loose wheel bearings, bad front end alignment, and a few other things.
    Did you deflate them to ~20psi, or is the the first time you've checked them in a while? Is the front sway bar still installed?
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    well my tires sayy 20 psi max
  4. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Ah, I see (looked at your sig). One thing about tire sidewalls getting taller is that extra sidewall flex effectively loosens your steering feel a little bit, makes it a steer a little sloppier.
