Swing away Spare tire carrier
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chosen1, Jan 1, 2002.
  1. chosen1
    chosen1 Registered Member
    Nov 5, 2001
    24
    Cudahy Wisconsin USA
    Does anyone have any information on a factory swing away spare tire carrier for my 78 K5? I would like to buy a COMPLETE Assembly, also would like if someone could send me detailed photos. Where can I get one? and how much $$$$$$?? Are these Strong??? Thanks for your time!!!!
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    if you want one for bigger tires look into what Sec offers. they have a set up that looks factory but is way stronger. go to project vechicles and click on UAV. there should be a section at the bottom for SEC.
    <a target="_blank" href=http://coloradoK5.com/gallery/Pauls89K5>http://coloradoK5.com/gallery/Pauls89K5</a>
  3. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Fredd over at SEC is recovering from major heart surgery so is not currently fabbing bumpers. Mo. Offroad Outfitters has a swing away rear. Check their site - I think the link for their truss (that will also take you to bumpers) is on CK5 home page.
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    <a target="_blank" href=http://www.mooffroadoutfitters.rockcrawler.com>Missouri Offroad Outfitters</a> they should have what you want.....
    &lt;&gt;&lt;<a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>&gt;&lt;&gt;
    Suck Fumes Ford Boy
    I'm in shape.... round is a shape......
  5. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Warn also sells one that attaches to their bumper
    C'moe
    Kill Roy was here!
  6. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    The factory (GM) swing away cariers are not very strong and the sheetmetal attachment points eventually break out. Poor choice for tire carriers. Most after market ones are much stronger.
    87 K5, 427BBC,D60 &amp; 14BFF, NV4500, NP208, TSM disc's,
  7. Headbanger
    Headbanger 1/2 ton status
    Nov 29, 2001
    123
    Moreno Valley, California. U.S.A.
    The strength of most swing away carriers is not the question in most cases. The strength of the tailgate sheetmetal is not strong enough to support the tire carrier without either interior or exterior reinforcement. Believe me, I've got the ripped sheetmetal to prove it!!!!!!
  8. Tatman
    Tatman Registered Member
    Oct 2, 2001
    80
    Indiana
    Or you could build your own. Check this one out at my site. Made with 2x2 tubing and a trailer hub. Talk about strong! But you better have the strong bumper to weld it to. Even this channel bumper flexes a little when I put my weight on the carrier when it's open.
    Brian
    <a target="_blank" href=http://www.saddletramps.com/BlazerK5.htm>www.saddletramps.com/BlazerK5.htm</a>
  9. dyeager535
    26,979
    As others have said, these are not the greatest setup for even 31" tires probably. I plan on running one, but definitely have to come up with a way to reinforce everything to put a 33 on it, if it will even fit.
    As well, no proof so far that these are even factory. Almost certainly not a factory option for 81-91's. I've no proof to back that up, except for 85-86 there are none listed in the GM parts manual. The 1982 service manual does not cover any exteriror tire mount, nor, if I remember correctly, does the "owners manual" for an '86. Also, I have yet to see an option code for the exterior spare tire carrier, (K5 specific) regardless of year.
    if GM had produced and installed these, I have a feeling they would have done a better job reinforcing the body. If you notice, as you see these mounts on trucks, there are at least two different styles, one with a "support" bar along the upper side of the tailgate, and others with just a 3 bolt bracket on the tailgate.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
