switc on firewall,. green wires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Nov 3, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    on this 81 C-10 305 ESC system th350 there is a switch thing yof some kind mounted at top of firewall betweeen brakes booster and center of firewall at about above the LH valve cover and it has light and dark green wires attached to it and about a 7/32" vacuum hose runs to it too. any ideas what part of emissions it is and what vacuum sourcew it shouldf recieve- manifold or ported ?
    thanks for anything
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    That is the MAP sensor Manifold Absolute Pressure.
    My guess is the manifold?
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    no, not the MAP,. its mounted elsewhere, i was told its my TCC switch for th350 torque converter lockup,
    thanks
  4. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Then it's also on the manifold. There is a hard line on the right back side of the carb if I recall right.
  5. dyeager535
    26,975
    Based on vintage and tranny, (along with the 700R4 setups I've seen) it's likely the TCC vac switch, and should be manifold vac.
    I think ESC only used the knock sensor...
