Switch gears or whole axle?
Discussion in 'The Garage' started by 88K5Jimmy, Apr 5, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    This is all on my 10-bolt front axle. I picked up my donor axle to swap under the front of my Jimmy because it has the gears I need. I got to thinking, could I just take out the gears, carrier and pinion shaft and swap that into my existing axle? Do I have to worry about shimming and all the other stuff associated with a rear gear swap or is it something a shade-tree mechanic can do? Or would it be better to just swap in the complete axle?
    Ross
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    You will still have to set backlash and pinion depth and run a pattern just like any gear install... Your better off switching the whole axle out unless you have the equipment to do the gear install.
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I agree, you will have to ck/reshim center section. If you can't do that, swap the axel.
